This powerful 4.0 inch square LCD touchscreen module boasts a vibrant 3.95 inch display with a sharp 480x480 resolution and a sleek 1:1 aspect ratio. The LCD screen uses the ST7701S as the driving IC, and the cable interface is composed of a 40-pin 3-wire SPI+RGB interface. For easier use, we have adopted a standard HD interface, which requires us to equip a HD driving board that uses the RTD2660H as the main controller. The display uses capacitive touch technology and you can enjoy vivid colors and clear images from any angle thanks to its IPS wide-viewing angle technology. It's easy to connect with its plug-and-play HD interface, working seamlessly with popular boards like Raspberry Pi, Beaglebone, and Jetson Nano.
Whether you're building a DIY project, working with embedded systems, creating medical devices, exploring industrial control, designing IoT devices, upgrading your smart home, or bringing any other creative project to life, this display is a fantastic option that delivers a comprehensive solution.
Pin Definition
Number |
Name |
Definition |
1 |
LED A |
LED ANODE |
2 |
LED K1 |
LED CATHODE |
3 |
LED K2 |
LED CATHODE |
4 |
GND |
Ground |
5 |
VCI |
Power Supply |
6 |
RESET |
Reset Signal, Active Low |
7 |
NC |
NC |
8 |
NC |
NC |
9 |
SDA |
SPI Data Signal |
10 |
SCK |
SPI Clock Signal |
11 |
CS |
SPI Chip Select Signal |
12 |
PCLK |
RGB Dot Clock Signal |
13 |
DE |
RGB Data Enable Signal |
14 |
VSYNC |
RGB Frame Synchronizing Signal |
15 |
HSYNC |
RGB Line Synchronizing Signal |
16~33 |
DB0~DB17 |
RGB Data Signal(DB0:BIUE,LSB:DB5:BIUE, MSB;DB6:GREEN LSB:DB11:GREEN,MSB;DB12:RED,LSB; DB17:RED,MSB) |
34 |
GND |
Ground |
35 |
TP_ INT |
Touch Interrupt |
36 |
TP_ SDA |
Touch IIC Data signal |
37 |
TP_ SCL |
Touch IIC Clock signal |
38 |
TP_ RESET |
Touch Reset Signal |
39 |
TP_VCI |
Touch Power supply |
40 |
GND |
Ground |
Note:SPI+RGB Interface
- 480*480 resolution, support capacitive touch;
- Using ST7701S driver IC, supporting 3 line SPI+RGB interface;
- Compatible with multiple systems (Raspbian、Ubuntu、Windows、Android、MAC OS and Chrome OS);
- Plug and play, use HD interface, easy to use;
- IPS full-view angle technology, providing vibrant and colorful visuals from any angle;
- Suitable for various scenarios including DIY projects, embedded systems, medical devices, industrial control, IoT devices, and smart homes.
Size |
3.95 inch |
Resolution |
480*480 |
Screen Type |
IPS TFT LCD |
Touch Type |
Capacitive Touch |
Viewing Angle |
Full Viewing Angle |
LCD Driver Chip |
ST7701S |
Display Driver Chip |
RTD2660H |
LCD Module interface |
40P(3 line SPI+RGB) |
HD input interface |
Mini HD Interface |
Power Interface |
Micro USB Interface |
Audio output |
Double Speaker Interface |
Number of pins |
Plug in 40pin |
Operation Voltage |
3.3V |
Operation Temperature |
-20℃+70℃ |
Backlight Control Button |
Yes |
Active Area |
71.86*70.18mm |
Module Dimension |
84.3*84.3mm |
- 1x 4 inch square IPS display with HD board
- 1x Micro HD to Mini HD cable
