Winny Gwo
Enhanced peripherals further expand the board's usability. It includes a microSD card slot for high-speed storage, a UART connector, 2 USB 3.0 ports supporting lightning-fast 5Gbps data transfer, and two additional USB 2.0 ports. Additionally, there's 1 RTC for precise timing, and 2 HDR-enabled 4Kp60 display outputs, allowing you to enjoy stunning visuals on multiple monitors. The Everything computer. Optimised.
hahahahahaha
The board includes 10 APA102 addressable LEDs controlled by the on-board ATtiny85. Includes 10 APA102C LEDs controlled by the aforementioned ATtiny85. APA102C LEDs operate just like most addressable LEDs over a two-wire interface. The board ties that interface to the ATTiny85 and operates both the IC and LEDs at 3.3V logic. Board Dimensions
66666666666666666666666666666666
very good
aaa test from jacki
tete es from jackit 20240521 tete es from jackit 20240521 tete es from jackit 20240521 tete es from jackit 20240521 tete es from jackit 20240521
Specifications A beautiful soldering kit designed to look like an enamel pin, featuring a rare two-tone soldermask effect. Wear as a flashing badge when complete. Kit includes custom designed printed circuit board, LED's, switch, badge pin and clasp, battery holder, and a screw to keep the battery secure. Follow instructions on the back or watch assembly youtube video:
fdfdfadsfdafasd
dfadfafadadf
fdgggggg
