The two biggest company of sharing bicycle is OfO and Mobike. Both of the bicycle are put into mass production to seize the market share.
2, Smart Lock with QR Code and Bluetooth Smart lock is the core parts of the motorcycle, which includes the motor components, the tongue drive components, the latch, the spring connected to the latch, with the groove of the lock pin, connected to the lock pin Of the spring, etc..When the user sweeps the confirmation information, the intelligent lock motor component output shaft rotates, drives the latch driving member to remove the lock tongue from the retaining groove of the locking pin, the locking pin is displaced to the unlocked state under the action of the tension spring; When the locking pin is pulled in the locking direction, the groove will move to the position corresponding to the locking tongue, and the latch will enter the groove under the thrust of the spring to lock the locking pin and complete the locking.
3, The anti-theft system of Real-time Positioning Mobike team know that security is the key to control the cost of operations, so the vehicle becomes not worthy of stealing into an important factor in the development. On the other hand, with the composite materials, engineering plastics and other manufacturing vehicles, making the bicycle in the raw material recycling market is not sold. On the other hand, the use of composite materials, engineering plastics and other manufacturing vehicles, If the lawless elements holding the death of the determination of forced to move how to do? which can collect vibration intensity information, when the violent damage caused by the vibration intensity exceeds the pre-set threshold, the vibration sensor will wake up the positioning module real-time acquisition of positioning information , While indicating the alarm module for alarm.
If you're willing to get hands on some of the Mobike technology, Simduino may help you. Elecrow SIMduino UNO+SIM808 GPRS/GSM Board has all the hardware function(GPRS/GSM, GPS) same as Mobike's. You can also realize these function with Sim808 shield. Maybe You can add another Relay shield to control lock. Wish you good luck.
Here is a video of how Mobike work.
