The CrowView Crowdfunding Campaign is live on Kickstarter now!
Prologue
Tired of working on a single screen? Need more screen real estate to boost your productivity? Whether you are a hardworking professional, a student, or a tech enthusiast, having the right display device can make all the difference. That's why we're excited to introduce Elecrow's newest monitor extender product - the  CrowView 14'' Portable Dual Monitor, which is now available for our crowdfunding campaign on Kickstarter.
 CrowView Live On Kickstarter
What makes CrowView Dual Monitor stand out?
Get ready to revolutionize the way you work, play, and create with the CrowView Dual Monitor. This innovative monitor extender offers a perfect dual-screen experience designed specifically for laptops. The CrowView 14" FHD 1080P IPS Mechanical Clamping Dual Display Portable Monitor is made of lightweight and ultra-thin engineering plastic material, providing portability and an excellent touch feel.
The unique mechanical clamping structure, with adjustable retractable clamps and soft cushion clamps, ensures a stable and secure structure that effectively prevents damage to your laptop's appearance. With CrowView, you can easily attach it to your laptop, giving you a fully functional dual-display setup no matter where you go.
CrowView is compatible with mainstream laptop models ranging from 13" to 16.5" and a thickness of 8mm or less. It also works with mainstream laptop operating systems such as Windows, Mac, Chrome, Linux, and Android. You can even use it as an external display for gaming consoles like Nintendo Switch, PS4, PS5, and Xbox.
CrowView
The monitor features two full-function Type-C interfaces on the side, allowing for a dual-screen function with just one cable. It also provides power and display signal transmission between the laptop and the monitor without the need for an external power source. Additionally, CrowView's low-power design helps reduce laptop power consumption.
The CrowView 14" Portable Dual Monitor's anti-glare and 3H Hardness surface treatment protects your eyes and screen from scratches. The external 5V-2A power supply and reserved interfaces ensure seamless connectivity and convenience. Get ready to experience the ultimate productivity boost with the CrowView Dual Monitor.
Wide Compatibility: The CrowView monitor boasts extensive compatibility, making it an ideal choice for mainstream laptops with screen sizes ranging from 13 to 16.5 inches. It's driver-free and works seamlessly with popular operating systems like Windows, Mac, Chrome, Linux, and Android. It can also be used with gaming consoles like Nintendo Switch, PS4, PS5, Xbox, and some Android phones. With two full-function Type-C ports, it supports plug-and-play functionality, creating a highly efficient dual-screen working environment.
Multiple Usage Scenarios: Thanks to its built-in metal hinge, the CrowView monitor can rotate in multiple directions and angles, allowing users to adjust its shape according to their needs. This versatile design makes it suitable for a variety of usage scenarios, as illustrated in the accompanying images.
Unique Clamping Structure: The CrowView monitor features a unique adjustable and retractable clamping design that is simple to operate. The contact surfaces are covered with soft material, which effectively prevents damage to the appearance of your laptop while offering a stable and secure structure. The mechanical clamping structure also eliminates the need for additional support and helps to avoid overburdening or damaging the laptop's hinge. With the support stand, the monitor can be tilted at an appropriate angle, providing a comfortable viewing experience.
Lightweight & Compact Design: Made of injection-molded engineering plastic, the CrowView monitor is slim and compact while ensuring structural rigidity. Its lightweight and portable design makes it perfect for mobile work scenarios such as business meetings and document presentations.
CrowView
Superior Display Quality: The monitor's high-quality display features Full HD 1920x1080p resolution, an IPS panel for wide viewing angles, up to 400 nits brightness, 8-bit color depth, and an A+ rated LCD module. This display provides clear and vibrant images, making it ideal for tasks that require precise and accurate color reproduction, such as graphic design and video editing. The wide viewing angles also make it easy to share your screen with others, making it suitable for presentations and teamwork.
Energy-Efficient: Designed with low-power hardware components specifically for laptops, the CrowView monitor consumes only 4.8W of power. It only requires a dual Type-C cable to connect to your device, and no additional power source is required. This power-saving design not only helps extend the battery life of your laptop but also makes the CrowView monitor an environmentally friendly choice.
 CrowView Rewards
 CrowView Rewards
The CrowView Specifications
Parameters
Product size
355x217x21mm
Thickness
10mm
800g
Screen Size
14 inch
Panel Type
IPS panel, wide viewing angle
Resolution
1920*1080p
Viewable area
309.312*173.988mm
Brightness
300~400nit
Aspect ratio
16:9
Refresh rate
60Hz
Color gamut
72% NTSC
Color depth
8bit
Contrast ratio
800:1
Surface treatment
Anti-glare, 3H hardness
Electrical characteristics
External power supply
5V-2A, with a power adapter
Reserved interface
a. Mini HDMI * 1;
b. Type-C * 2 (full-featured and power supply);
c. Headphone jack;
Reserved buttons (on the back of the screen)
a. Exit (return); (long press 3s, power on/off function)
b. "-" Down keys;
c. "+" Up keys;
d. Menu;
Indicator light (on the side of the screen)
Green light on: indicating that the product is in normal use;
Red light flashing: indicating that the power is on but there is no signal input;
Red light always on: indicating that the product is in sleep mode.
Supported Systems
Windows/Mac/Chrome/Linux/Android;
Compatible Devices: Switch/PS4/PS5/Xbox and other gaming consoles, some Android phones;
(Plug and play, no driver required)
OSD menu:
Built-in adjustment system, including brightness, contrast, image adjustment, color temperature adjustment, OSD settings, reset, and more;
Touch Function
Speaker
Built-in battery
jack
3.5mm headphone jack
CrowView: The Versatile Solution for All Your Display Needs
CrowView offers the ultimate solution for a diverse range of applications. Whether you need to complete daily office tasks, deliver presentations, work while traveling, edit videos, create graphics and images, develop software or code, play games, watch videos, or trade stocks, CrowView empowers you to work from anywhere and optimize your productivity.
 CrowView
CrowView: The Display Solution for Everyone
CrowView is perfect for business professionals, graphic designers, stock traders, digital enthusiasts, frequent travelers, gamers, software developers, finance and accounting professionals, video editors, and anyone who needs to be productive on the go. It's also great for students who need to work on multiple projects at once or anyone who needs more screen real estate to get their work done. If you're looking for a tool that will dramatically improve your productivity and efficiency, CrowView is the perfect choice. Order yours today and experience the next level of productivity and efficiency no matter where you are or what you're working on!
The CrowView Package List
  • CrowView *1
  • Power Adapter (5V-2A) *1
  • Velcro Tie*2
  • Detachable Clip*1
  • USB-A to USB-C Cable*1
  • USB-C to USB-C Cable *1
  • HDMI to Mini HDMI Cable*1
  • User Manual*1
The Crowdfunding Campaign Is In Full Swing Now!
The crowdfunding campaign for the CrowView 14'' Dual Monitor is starting now on kickstarter.com. Stay tuned for updates and early bird specials. With CrowView's energy-saving design, broad compatibility, easy-to-use features, and high-pixel-count dual monitor, CrowView is the perfect solution for anyone looking to increase their productivity.
CrowView Kickstarter Campaign
Don't miss your chance to support this exciting project and supercharge your work efficiency and enhance your work-from-home setup.
To learn more about the CrowView 14" Monitor Extender, please contact Elecrow for more information. And if you are interested in turning your own DIY electronics ideas into realistic products, but are worried about not having a professional team to support you, feel free to join Elecrow's Partner Seller Program, where you can earn money and mass-produce your DIY electronics products for commercial purposes.
