Not all of us we’re able to buy or get CrowPi for our own, In Elecrow, we care about all our customers so we crafted a special tutorial on how to use Minecraft magic blocks with NFC chips without CrowPi!
![Play minecraft with Raspberry Pi 3](https://tete.elecrow.com/media/magefan_blog/2019/01/Play-minecraft-with-Raspberry-Pi-3-e1548644271926.jpg)
Follow this instructions step by step on your fresh new raspberry pi image in order to get the RFID working on your raspberry pi with RC-522 module and be able to play using RFID Module and the NFC chips!
https://github.com/Elecrow-keen/CrowPi.git clone and install the RC-522 driver from the Drivers/RFID/ directory using the command "python setup.py install"
After installing the driver, make sure to connect the RFID module properly to your raspberry pi:
Check the following pins information and connect it by the by the BCM (physical pins) names, make sure you connect everything properly else the project might not work!
![NFC Minecraft Project cable connection](https://tete.elecrow.com/media/magefan_blog/2019/01/NFC-Minecraft-Project-cable-connection-e1548643998958.jpg)
MISO => PIN21 (SPI_MISO)
MOSI => PIN19 (SPI_MOSI)
SCK => PIN23 (SPI_CLK)
SDA => PIN24 (CE0)
IRQ => PIN18 (GPIO24)
GND => PIN6 (GND)
3.3V => PIN1 (3.3v)
RST => PIN39 (GND)
![Image result for raspberry pi 3 GPIo](https://www.element14.com/community/servlet/JiveServlet/previewBody/73950-102-12-339300/pi3_gpio.png)
After you successfully connected and installed the driver it’s time to test it!
From inside of the CrowPi folder, run the following command: “sudo python RFID_Read.py” now try to touch using one of the NFC tags on top of the RC-522 module, it should be able to read it!
If everything is fine, you can now follow the Minecraft tutorial and lessons and all the functionalities now will work for you exactly as they work on the CrowPi!
[video width="960" height="544" mp4="https://tete.elecrow.com/media/magefan_blog/2019/01/Play-minecraft-with-RPI-1.mp4"][/video]
Here are the links you may need
Buy the RFID Reader and card
https://www.elecrow.com/rfid-reader-with-cards-kit-1356mhz-p-756.html
Buy Raspberry Pi monitor
http://www.elecrow.com/display-1.html
Buy Raspberry Pi adpter
https://www.elecrow.com/raspberry-pi-3b-power-adapter-micro-usb-with-switch-button-us-eu-au-uk-plug-type.html
Buy Raspberry Pi 3 model B+
https://www.elecrow.com/raspberry-pi-3-model-b.html
Download all the Minecraft lessons with Raspberry Pi
https://www.elecrow.com/download/crowpi/Minecraft-Lessons.pdf
Find the Minecraft blocks paper folder
